S80, Diagnostic Software
Old Aug 17, 2009 | 07:01 PM
  #41
I have not tried anything yet with Vadis. I have an elmscan ISO interface box I am eventually going to try to get Vadis to work using it. I have not had time to mess with it though.
Old Aug 18, 2009 | 05:28 PM
  #42
comrade904's Avatar
I thought the elmscan wasn't a j2534 compliant pass through?
Old Aug 18, 2009 | 07:33 PM
  #43
Im not sure if it is or not. Haven't had much time to mess with it.
Old Aug 19, 2009 | 03:43 PM
  #44
comrade904's Avatar
What is the difference between the VADIS and VIDA? I have the Vadis, but most of the volvo compatible j2534 pass throughs specifically say Volvo VIDA, but don't say anything about Vidas. Are they the same thing?
Old Aug 19, 2009 | 08:04 PM
  #45
Vida is a web based program that you have to pay for to use.
Vadis is stored on the computers hard drive.
Old Aug 5, 2010 | 01:57 PM
  #46
thewildwon's Avatar
Default so
if i don't have the money to buy the scanner right now, can i just run it as a program on my pc? I'm running Win 7, 64-bit.
Old Aug 5, 2010 | 06:32 PM
  #47
andrei3333's Avatar
Thats how it runs, you dont need a scanner, its optional i believe
Old Aug 7, 2010 | 05:25 PM
  #48
stylz's Avatar
greetings guys,
Any ideas on what diagnostic kit to use for my new Volvo S80, 2008 model.
please!
Old Oct 27, 2010 | 09:46 AM
  #49
commops106's Avatar
Default need vadis
can someone repost a working link can't find torrents anywhere and pirate bay is down!!!
Old Oct 27, 2010 | 01:13 PM
  #50
volvoedmonton's Avatar
i got vadis from torrents loaded on my laptop,now the problem is i don't have diagonistic scanner cable.Is it possible to use a OBD II scanner cable
Old Oct 27, 2010 | 01:21 PM
  #51
commops106's Avatar
You need a vct2000 interface with cable
Or the newer volvo dice which is usb bluetooth
Old Oct 31, 2010 | 07:10 PM
  #52
commops106's Avatar
anyone figure out how to install vadis on a d: drive it only installs c: my laptop c: is full
Old Dec 1, 2010 | 11:22 PM
  #53
comrade904's Avatar
GOT IT!!!
Vida2010b off ebay, and Cardaq-Plus works!!!
Any old j2534 should be able use all the included tools.
Beware Vida2010 does not like to install on anything other than (xp sp3 x86) however, I am running Win7x64 with "xp mode" because regular compatibility modes don't work. "Xp mode" is a free virtual machine software released by microsoft for businesses that depend on software that is incompatible with windows7. LIKE VIDA!!!
Old Jan 26, 2011 | 12:33 PM
  #54
NoLifeTilBoost's Avatar
Originally Posted by comrade904
GOT IT!!!
VIDA or VADIS? I have VADIS running on Win7 64bit in "compatibility mode" as opposed to XP mode. I cant imagine VIDA being less up to date.
Old Jan 27, 2011 | 02:54 AM
  #55
comrade904's Avatar
Vida. The install literally had a problem with the OS version. I tried compatibility mode on the install file, and all the system check modules, no dice. The VIDA suite is amazing for troubleshooting. I only had one thing to troubleshoot but I could see and try all the troubleshooting options available.
NO JOKE these cars are so wired that with VIDA you can control the seat position motors from your laptop. Almost anything that the ecu controls can be toggled on or off like the purge valve that is throwing my OBD codes.
Trouble shooting works something like toggling the purge valve and watch the pressure values on the laptop which obviously didn't change indicating a problem. However I could hear the fuel tank leak when I toggled it, so I knew the valve works.
Old Feb 2, 2011 | 12:33 PM
  #56
Abacusvolvo's Avatar
Default Compatible with 2006 models?
I just purchased a 2006 S60 and was wondering if these software Vadis or Vida cover this newer model? I read somewhere that the free download for Vadis is up to 2005 models. Thanks for your help in advance.
Old Mar 16, 2011 | 04:15 PM
  #57
s80newb's Avatar
Anyone know what exactly the following codes for '02 s80 t6 mean?
P0422 catalyst
P0432 catalyst
I've been told that they mean the cats need replacing but also might just need to replace the 02 sensors because they're in the cats. I'm not sure what exactly is going on but the check engine light comes on then goes off soon after. It was deleted when my friend hooked up the diagnos. I'm not sure if it will come back on or not. At any rate, I'm not losing power and seems to be running fine. Just don't want to have to shell out 500+ for 2 new cats, any ideads?
Old Mar 16, 2011 | 08:08 PM
  #58
Any misfiring at all?
It might just be an O2 sensor.
Old Mar 17, 2011 | 07:45 AM
  #59
s80newb's Avatar
No, none at all. I'm hoping that's all it is.
Old Mar 17, 2011 | 08:09 PM
  #60
Find someone that can read real time Data and compare both front sensors and see what they are doing.
