Timing Belt Precautions!!
Old Aug 30, 2013 | 06:07 PM
  #61
KelliAnn19's Avatar
Default Manual
I'm going to replace my timing belt next weekend and am wondering what the best manual is to get?
Old Aug 30, 2013 | 10:14 PM
  #62
difflock54's Avatar
Timing belts deteriorate due to age as well as mileage.
After 14 years I would definately replace the belt despite being a long way short of 105,000 miles.
Your waterpump,tensioner and seals may be close to becoming problems also simply due to the time factor???
Old Aug 31, 2013 | 11:33 AM
  #63
You would rather have a manual than a video? SMH
Old Nov 16, 2013 | 11:39 AM
  #64
Matthew Wheeland's Avatar
Hello, I just bought a 98 S70 T5 with 183,000 miles. I have no idea when the timing belt was replaced, so it's the first thing on my list of things to do. I'm going to replace tensioner, pullys, water pump & belt. The question I have for you is. Is there a brand of timing belt that is better then others. Should I go back with OEM or can I try something different.
Old Sep 9, 2014 | 10:48 AM
  #65
golive's Avatar
I own a 2001 v70 wagon. 140,000 miles and as far as I know the timing belt has not been replaced. I am moving forward to do this soon however the auto repair place I would normally go to has recommended replacing the water pump at the same time to avoid labor costs in the future. The Volvo dealership I called to ask a quote from said there should never be any issue with the water pump and wouldn't recommend replacing. Not sure who to believe. Please advise.
Old Sep 9, 2014 | 10:52 AM
  #66
golive's Avatar
So when the dealership says there should almost never be an issue with the water pump is that just a standard answer?
Old Sep 9, 2014 | 11:14 AM
  #67
golive's Avatar
You described exactly what has been recommended to be done with my car. I did have some doubt about the water pump being replaced unnecessarily. It's a big ticket for me but I guess I need to bite the bullet.
Old Nov 5, 2014 | 03:04 AM
  #68
emilius's Avatar
I need a timing belt replaced on my 99 v70 2.5l
What the cheapest source and to have it sent to new zealand.
Including idlers etc.
Emil
Old Nov 7, 2014 | 07:51 PM
  #69
Junk yard parts. Why would you want the "cheapest" parts to go on the most important part of your motor?
Old Nov 8, 2014 | 10:28 AM
  #70
rodneygt's Avatar
He asked for the "cheapest source" not cheap parts.
Old Oct 14, 2018 | 11:41 PM
  #71
jenkinskg@yahoo.com's Avatar
In above posts people failed to mention, years and miles matter.
My 04 c70 had 82K, but was over 10 years old, did both belts as soon as I got it home
Old Nov 25, 2020 | 02:30 PM
  #72
peirzac1's Avatar
Wow... I didn't even know it was an interference engine... glad I replaced all my stuff!
tech
Jun 5, 2020 10:22 PM
tech
Mar 30, 2020 11:50 PM
tech
Sep 23, 2019 04:21 PM
tech
Oct 10, 2016 06:22 PM
tech
Aug 6, 2015 12:52 PM
