Dash?
Old Feb 23, 2005 | 06:52 PM
userdead626's Avatar
Default Dash?
Hey does anyone have a diagram of the proper way to remove the dash panels on an 05 s60?
Old Feb 23, 2005 | 07:38 PM
Default RE: Dash?
Which part of the dash are you trying to remove?
Old Feb 23, 2005 | 11:51 PM
Default RE: Dash?
mainly the panels around the radio, i have to run an antenna from the rear of the vehicle, and i think im gonna run the wire through the ac vent, so i need to get the panels around the center vents out.
Old Feb 24, 2005 | 10:05 AM
Default RE: Dash?
If you look under the A/C panel there is the pen holder or the little panel if you don't have the pen holder.Remove that panel and remove the 2 T-25 screws.Lift up slightly on the A/C panel then pull straight back to unlatch it from the bottom of the radio assy.Then you will see screws to remove the radio.That should get you started.
Old Feb 24, 2005 | 06:38 PM
Default RE: Dash?
how do you remove the pen holder?
Old Feb 26, 2005 | 11:06 AM
Default RE: Dash?
You need to use a small screwdriver and put it under one of the corners and pull out.You may have to hold that side and do the same on the other side.
Old May 28, 2005 | 07:29 AM
pete13's Avatar
Default RE: Dash?
Tech is it possible to change the A/C panel from a manual to digital type
Old May 28, 2005 | 02:00 PM
Default RE: Dash?
It would not be worth doing it.
You would have to remove the dash and replace tons of parts.
trs80
Jun 25, 2011 02:05 PM
tr_car_nut
Jan 19, 2008 09:37 AM
gstohl
Aug 26, 2006 05:26 AM
Erock198
Aug 3, 2004 02:09 PM
