94 960 door panel removal
Old Jun 24, 2007 | 12:56 PM
sjp960's Avatar
Default 94 960 door panel removal
The passenger side window doesn't close properly on my 94 960. My Chilton manual is rather generic on door panel removal. One of the first steps is to remove the inside handle, but I can't figure out how to get it off. The handle (what you grab to pull back and open the door) has a plastic cube that I think you must remove, but I can't figure out how to get it off. It doesn't seem to just pop off. What is the trick to removing it (and any other advice on removing the door panel).
steve p.
Old Nov 14, 2009 | 09:36 PM
Default Door panel removal on a Volvo 960
Here are some photo instructions on how to remove a door panel on a 1997 Volvo 960. Should be the same for all of the 900 series Volvos, including the 940 and S90. Let me know if someone finds something different.
http://www.atthetipwebs.com/technolo...el_removal.htm
I removed the panel because my drivers side window was squealing like a pig whenever I rolled the window down. So I had to lubricate the rear window track with general purpose grease.
alsweet1
Apr 26, 2009 10:00 PM
redmenaceT6
Nov 16, 2008 08:28 AM
etype38
Aug 1, 2008 07:11 PM
air2fakie
Jan 17, 2008 04:47 PM
RedTurbo850
Jan 12, 2007 09:40 PM
