SCANCODE P0116 - Engine Coolant Temperature Circuit
Old 04-09-2008, 04:25 PM
98c70turbo's Avatar
Default SCANCODE P0116 - Engine Coolant Temperature Circuit
I've been having this problem for months, my check engine light wont go off, and when i scan the code I get is:
I've changed, the fan relay, thermostat, cooling temp sensor, still same problem
Please help
Old 04-09-2008, 05:49 PM
Default RE: SCANCODE P0116 - Engine Coolant Temperature Circuit
Very strange OEM parts?
Old 04-09-2008, 05:52 PM
98c70turbo's Avatar
yeh I was worried thats what you were gonna say... aggghh
yes all OEM parts... what should I do?
Old 04-09-2008, 06:10 PM
Can you read realtime with your scanner?
If so see what the coolant temp is reading.
Old 04-10-2008, 08:46 AM
98c70turbo's Avatar
yes I think I can get that, I'll have to check tonight and let you know... what should I be looking for?
Old 04-12-2008, 07:45 AM
See what the temp is saying it is.
Old 04-12-2008, 12:12 PM
98c70turbo's Avatar
after the car was on for about 6-7 mins, reading 82, sounds about right?
could it have anything to do with the computer... hope not
Old 04-12-2008, 10:59 PM
Try driving it for about 15 minutes and then let it idle for a few and see if it is still the same.
Old 04-13-2008, 09:25 PM
98c70turbo's Avatar
did that, went to 84.. when I turn the car off the fan stays on for about 5-10 mins
Old 04-14-2008, 08:06 PM
Maybe something wrong with the new sensor.
Is it low when cold?
Old 04-16-2008, 12:24 PM
98c70turbo's Avatar
yeh its a little low when cold... I have a spare sensor lying around that I'll try, maybe I'll try a new thermostat as well, no harm in that....
Could it be the computer though? Sending a wrong signal? I hope this doesnt turn out to be a HUGE problem thats not worth the cost... I luv this car too much
Old 04-16-2008, 06:40 PM
The computers aren't known to have problems like this.
Old 04-21-2008, 03:55 PM
98c70turbo's Avatar
Tech.. you are the man!
Thanks for your help, I had a spare sensor and thermostat hanging around soI changed them both.. and Voila... four days.. no problem! I brought them both back to volvo, and they gave me a refund on the thermostat.. it was faulty!
I guess this is why I had no cabin heat and a problem starting in sub zero temps
glad its over
Old 04-21-2008, 08:50 PM
Congrats!!
newvovofan
10-22-2010 06:29 AM
oldmots
04-27-2010 09:24 AM
ivx675
03-27-2010 01:36 PM
joshuab
03-17-2009 05:44 PM
Quick Reply: SCANCODE P0116 - Engine Coolant Temperature Circuit
