C70 Headlight Replacement
Old Apr 22, 2008 | 08:52 AM
cannon cocker's Avatar
Default C70 Headlight Replacement
The passenger side headlight lens on my 2001 C70 (conv). I found an entire assembly for a good price, but just want to replace the lens (unless it's easier to do the whole thing). If some one has time to offer up a "step by step" procedure I would be very grateful.
Perry
Old Apr 22, 2008 | 08:54 PM
JPN's Avatar
JPN
Default RE: C70 Headlight Replacement
Hi Perry,
Unfortunately, I am not privy to the C70s. If the lens is glued onto the reflector assy, you may want to do the entire assy. If not, I believe a gentleman by the name of Reg or Moderator Tech would know the procedure.
If you did not receive replies, try doing it yourself. Carefully check to see what kind of fasteners are installed, then undo the bulb connectors and replace the assy. If you take some close-up photos,someone, including myself, may be able to help you.
JPN
robinsonparker
Jan 21, 2015 06:13 AM
cb1313
Dec 7, 2010 06:16 AM
Peter1234
Nov 23, 2010 01:19 PM
scoutdavis
Sep 22, 2004 08:49 PM
