s70 turbo intake
Old Jun 3, 2008 | 02:12 AM
crunch5868's Avatar
Default s70 turbo intake
I was wondering if i should remove some of the air box in my s70 t5. I want it to sound better however if I will lose HP then i wont. I only ask because i know it is really restrictive and also quiets it. I am also thinking about removing the pipe that brings heat from the exhaust to intake and running a new pipe from the box to let cool air in from this pipe. Im not looking at spending any money except for maybe a new filter because my cars old and falling apart and in 4 months im going to be in college and barely driving it. With a rough 160,xxx any investment isnt worth it on my car.
Old Jun 3, 2008 | 07:29 AM
mcguij1's Avatar
Default RE: s70 turbo intake
either get the EuroSportTuning ram air intake like a bunch of us have including s70driver or get a k&n drop in filter....
Old Jun 3, 2008 | 07:35 AM
If he's not willing to spend much money he wont want to buy an EST intake.
To be honest if your only willing to buy an air filter just buy a cheap one and slap it on the end of your MAF. You wont have any heat shielding but hey your not willing to spend much money.
You will get the sound you want.
Old Jun 3, 2008 | 11:26 PM
crunch5868's Avatar
s70 im going to go and do that. So will i be all set if just buy an air filter such as http://www.eurosporttuning.ca/Mercha...Category_Code=
. i can figure it out from there if thats all i need. thanks
Old Jun 4, 2008 | 07:28 AM
You will need a Torx screw driver, I forget which size.
1. Romove the MAF from the top of the airbox by using the torx screw driver and removing the two torx screws holding it in place.
2. Remove the top of the airbox.
3. Put the cone filter on the end of the MAF and tighten it down and lay it down inside the bottom of the airbox.
And your done.
Simple mod, no heat protection though. So you more then likely wont see any gains, you wil get a sound but you may loose power too.
Old Jun 4, 2008 | 12:09 PM
crunch5868's Avatar
what do you mean by the cone filter, do you mean one that I would purchase?
Old Jun 4, 2008 | 04:19 PM
mcguij1's Avatar
yes
Old Jun 4, 2008 | 05:06 PM
A cone filter is just that a cone filter. How else are you going to get one unless you buy it? You going to steal it I doubt it.
If you don't know what a cone filter is, go to the K&amp\\;N website and look one up or even use GOOGLE to IMAGE search it sand type in CONE FILTER. You can get cheap ones for under $30 I believe at Advanced Auto Parts which is a auto parts store or other places like Pep Boys which is another auto parts store. Stock your car uses a panel filter. There is a difference.
1. A panel filter looks like a panel shaped filter.
2. A cone filter looks like a cone shaped filter.
They are disticntly different and you will know the difference once you see both of them.&lt\\;
Old Jun 4, 2008 | 11:29 PM
crunch5868's Avatar
yeah thanks i know what my car takes stock and what a cone is and all that stuff, i just wasnt sure what you were talking about. i also asked because it was about 3 in the morning when i checked ur repsonse and wasnt about to check my car so i just asked anyways. thanks though
Old Dec 17, 2008 | 09:03 PM
elcs70's Avatar
smart ***..lmao haha
Jeff Kong
1998-2000 model year V70
May 18, 2012 05:38 PM
Stefan1235
May 21, 2011 09:00 PM
jg1
Aug 1, 2009 12:43 AM
rquinonez32
Sep 30, 2008 02:08 PM
JBVolvo
Apr 6, 2007 10:17 PM
