Intake Torque's and intake Gasket
Old Apr 6, 2007 | 02:48 PM
JBVolvo's Avatar
Default Intake Torque's and intake Gasket
Hey -
When removing the intake for the purpose of PCV system replacement, what is the reccommended torque for the intake bolts? Is there a torque pattern, and do you use anything (sticky) to keep the replacement gasket in placeduring reassembly?
Thanks
Josh
Old Apr 6, 2007 | 07:37 PM
billofdurham's Avatar
Default RE: Intake Torque's and intake Gasket
Torque is 20nm with no specific sequence.
Locate the gasket on the head and fit the lower manifold bolts a few turns prior to fitting the manifold. The bottom holes in the manifold are slotted so you can slide it on to the lower bolts.
Old Apr 6, 2007 | 09:32 PM
JBVolvo's Avatar
Thanks for the info bud. But what is 20nm?
Did you mean 20 inch lbs?
Old Apr 6, 2007 | 10:17 PM
JPN's Avatar
JPN
Message deleted.
Indy S60
Oct 19, 2023 12:05 AM
dpagini
Jul 2, 2014 07:31 PM
GrantRobertson
Jul 2, 2013 01:49 AM
XL883L
Jun 27, 2006 06:30 PM
wavewright
Apr 23, 2005 12:57 PM
