98 S70 GLT alarm not sounding
Old Jun 13, 2008 | 02:46 PM
S70GLT's Avatar
Default 98 S70 GLT alarm not sounding
When the alarm is triggered, the 4-ways flash, but no sound comes out. It used to work correctly until it went off one day and faded away as a scratchy noise for good within 10 seconds.
My horn still works though. So I'm confused as to why this has happened. Anyone know what could be the root of this issue?
Thanks all.
Old Jun 13, 2008 | 08:39 PM
Default RE: 98 S70 GLT alarm not sounding
The alarm horn is different from the normal horn. The alarm one is mounted on the firewall by upper mount.
Old Jun 14, 2008 | 12:53 AM
S70GLT's Avatar
Thanks, I'll check it out in the morning.
Old Jun 15, 2008 | 12:04 PM
samadkins29's Avatar
yu can trigger the alarm and look under the hood where tech said, it might still move but make no sound. Try tightening it up if its lose.
Old Jun 15, 2008 | 02:22 PM
S70GLT's Avatar
Found it, and it was in fact loose, after tightening, it still did not work, I am going to try and modify the 850 alarm horn so that the plug works with the S70's.. will this work? they appear to be the same..
Old Jun 15, 2008 | 03:54 PM
That should work fine.
Old Jun 15, 2008 | 06:13 PM
S70GLT's Avatar
Thanks for your input tech
Vone
Mar 31, 2014 11:05 PM
Cyburg
Aug 31, 2009 06:09 PM
eyeballumbrella
Feb 9, 2009 05:42 AM
crunch5868
Intake, Headers and Exhaust
Jan 11, 2009 08:30 PM
805c70
Aug 30, 2007 02:07 PM
