XC70 Rear Brake Light Relay Diagram
Old Sep 1, 2008 | 06:13 AM
bundubasher's Avatar
Default XC70 Rear Brake Light Relay Diagram
Hi everybody,
does anyone have a diagram of the rear relay board for the XC70? I have both back brake lights not working while the centre high mounted LED one does. That with the instrument console reporting a brake light failurediscountsa faulty switchat the pedal. Fuse and light bulbs check out OK (I changed the bulbs just in case) so I can only imagine that it must be the relays...
Thanks.
PS Does anyone know what the 'shunts' do?
Old Sep 1, 2008 | 08:33 AM
Default RE: XC70 Rear Brake Light Relay Diagram
Check relay RM15 it is on the R/S row of the relays.
Old Jul 25, 2010 | 08:12 AM
pdunn's Avatar
I have the opposite problem.
My upper LED brake light does not work, regular rear braking bulbs do work. However I have a a bulb failure dash light coming on with my Left turn signal only, and although signal works (front and rear) it does indicate much quicker than the right, like 1 bulb is out.
dool
1998-2000 model year V70
Aug 21, 2015 03:24 AM
bennyd20
Aug 7, 2010 04:36 PM
honeyfixthecar
Jun 7, 2009 06:17 PM
lpr947
Apr 15, 2009 02:14 PM
mkelly85
Feb 15, 2008 05:53 PM
