V70 Rear Relay Diagram HELP!!!!
Old Aug 8, 2015 | 08:08 AM
dool's Avatar
Unhappy V70 Rear Relay Diagram HELP!!!!
Picked up a '00 V70 for $500 the other day
I am looking for the REM (Rear Electronic Module) Relay diagram. I have
the Fuse diagram from the owners manual. But I have spent the last 4hrs searching for the relay diagram..... As I would like to know what relay there
controls what.
The issue is that I have no control over my head lights (they come on and stay on), I also have no control over the headlight position or light dim on the interor. Also my central keylocking is not functioning correctly. I can manually use it if I press the button down, but they all pop back up again, My central locking does not work via the key. Also, the lock/unlock button the door does
not function either. Which is why I am looking at Relays and fuses. Because if
it was the key actuator, then the button on the door would still lock the doors. Which it does not. Also I can not lock the back tail gate.
So, yes, that is why I have been searching for the Diagram for the relays in the Rear Electronic Module.
Any help would be greatly appreciated
Old Aug 8, 2015 | 08:27 AM
dool's Avatar
Wow, talk about murphy's law, I found it.....
RMA1-Relay 15I Feed, Rear 2/52
RMA3-Relay, Heated Rear Window 2/82
RMI2-Unlocking Relay, RL 2/112
RMI3-Relay, Deadlock, Rear Door 2/115
RMI4-Relay, Reversing light 2/80
RMI5-Relay, brake lights
RMI6-Relay, fog light 2/49
RMI7-Relay, trailer fog light 2/83
RMI8-Relay, preheated fuel filter 2/142
RMI13-Relay, rear windows wiper 2/72
RMI14-Relay, rear adjustable head restraint 2/75
RMI16-Relay, intermittent rear windows wiping on/off 2/16
RMI17-Relay CNG/LPG 2/140
RMI19-Unlocking relay, tailgate 2/87
RMI20-Locking relay, rear doors, filler flap 2/158
RMI21-Unlocking relay, fuel filler flap 2/59
RMI23-Unlocking relay,RH rear 2/114
RSH2-Shunt, low beam REM 20/29
RSH3-Shunt, cargo compartment 12v outlet 20/39
RSH4-Shunt, Parking Light REM 20/28
RSH5-Shunt, parking light/tail REM 20/33
RSH6-Shunt, brake light REM 20/31
Old Aug 9, 2015 | 10:06 AM
ES6T's Avatar
There is no REM on a 2000 V70. Sure you don't have a 2001?
Old Aug 21, 2015 | 03:24 AM
dool's Avatar
ES6T Mine is plated 10/2000, but have been informed by Volvo Mechanic (whom I trust) that it is in fact a 2001 model. You are very correct my good sir.
bennyd20
Aug 7, 2010 04:36 PM
bundubasher
Jul 25, 2010 08:12 AM
honeyfixthecar
Jun 7, 2009 06:17 PM
lpr947
Apr 15, 2009 02:14 PM
mkelly85
Feb 15, 2008 05:53 PM
