Small bolt on the rotor hub: what's it for?
Old Jan 25, 2009 | 05:10 PM
Sabre's Avatar
Default Small bolt on the rotor hub: what's it for?
Hoping one of you tech guys will know this one....
I just fitted a set of four steel winter wheels onto our '04 S60. On each cast iron wheel hub, there's a small bolt with a 10 mm head. It's located half way between two of the threaded lug sockets. Of course, the OEM alloy wheels have a cast recess that fits over the bolt head. The steelies have a dimple, but it's not deep enough to clear the bolt head, so I had to grind down about half the bolt's head.
My question: what is this bolt for? Is is merely for assembly purposes? After the wheel is bolted on, I don't see what the bolt's purpose is. Could it be removed altogether?
Thanks in advance!
Old Jan 25, 2009 | 05:15 PM
Somthngfrce's Avatar
Default RE: Small bolt on the rotor hub: what's it for?
I belive that's the bolt that keeps your rotor locked in place
Old Jan 25, 2009 | 05:42 PM
Some people remove them but the rotor will flop around on the hub.
Old Jan 25, 2009 | 05:44 PM
Sabre's Avatar
ORIGINAL: tech
But not when the wheel is bolted on, right? I mean, it must be there just to keep the rotor from "flopping" on the assembly line, right?
Old Jan 25, 2009 | 05:48 PM
Yes and when you remove the wheel.
Once the lugs are tight it is tight. I just like to leave them so the rotors don't move when taking the rims on and off.
Old Feb 9, 2009 | 03:47 PM
jks2's Avatar
It also allows you to hang the wheel when you are putting the tires back on.
puxnstx
Dec 13, 2014 11:36 AM
jbooker82
Oct 19, 2011 05:25 AM
Counselor828
Aug 22, 2011 12:19 PM
NYSpeedRacer
Oct 12, 2006 09:18 PM
ripleydog
Jan 31, 2005 01:26 AM
