Rotor Hex Bolt Stuck
Old Oct 7, 2006 | 12:03 PM
NYSpeedRacer's Avatar
Default Rotor Hex Bolt Stuck
Anyone have any suggestion on how I can remove a the small bolt that holds the rear rotor in place on a 01 V40? It's rusted in and slightly worn from my allen key as I was trying to unscrew it? The car's been sitting on our driveway for a good year, if not two. Any suggestions would be helpful. Thanks in advance. I tried PB rust spray...anything else?
Old Oct 7, 2006 | 12:08 PM
Default RE: Rotor Hex Bolt Stuck
Do you have one of those Impact drivers that you can hit with a hammer and it turns to loosen the screw?
If all else fails and the rotor has 2 screws and one is stuck grind the head off the stuck one and leave it.
one should hold is fine.
Old Oct 7, 2006 | 12:12 PM
Impact driver? Where can I get one?
Old Oct 7, 2006 | 12:26 PM
They look like this Sears I believe also carries them.
http://www.harborfreight.com/cpi/cta...emnumber=46978
Old Oct 12, 2006 | 03:40 PM
Thanks for all the help, I drilled the entire screw out of the rotor. It took me a while, but finally got it off, but now the rotor is loose without that screw. Do anyone know the size and length of that screw so I can get one from Home Depot or is this a special dealer part as well? Is there a screw for the front rotors as well?
Old Oct 12, 2006 | 09:18 PM
I think it is a 6mm thread. But it is a short screw.
jbooker82
Oct 19, 2011 05:25 AM
Counselor828
Aug 22, 2011 12:19 PM
01_fast_ride
Mar 24, 2009 07:55 PM
Sabre
Suspension
Feb 9, 2009 03:47 PM
99VolvoV70
Aug 3, 2007 10:06 AM
