check engine light
Old Sep 25, 2005 | 01:32 PM
bill70's Avatar
Default check engine light
My gas cap was loose and I'm sure it caused my check engine light to come on. Is there an easy way to clear the code and get the light to go out? Does disconecting the battery for a time do it? Thanks for your help, Bill
Old Sep 25, 2005 | 11:37 PM
Default RE: check engine light
Most of the time it will not do it.
Stop by the local Auto Zone or Discount Auto Parts and have then clear the code.
Old Oct 1, 2005 | 05:21 PM
fire2havoc's Avatar
I have the same problem. Periodically, it says that the fuel cap is loose and then goes away, leaving only the check engine light on. I went to the mechanic who checked it out and said that the sensor is bad and there may be a very small, harmless leak somewhere in the piping. He told me that it is not worth fixing and certainly safe to drive regardless of the check engine. However, this is not always the case.
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
