Airbag needs to be reviewed urgent S60
Old Apr 11, 2004 | 04:19 AM
mvela's Avatar
Default Airbag needs to be reviewed urgent S60
I bought a newS60 two weeks ago, in two weeks theS60 failed 3 times. The failure is the same (3 times) and the dealer does not know the origin of the failure. The dealer reviewed it and alsorecharged the programs in the computer, but it failed again.</P>
Failure: When the car is locked I tried to unlocked using the remote control (key) but it did not work. I open the car with the key, get in the car and I tried to open and close the latches with the door control but it did not work ( I listen some noise but nothing works). I tried again with the remote control (key) and it did not work. When Iturn onthe engine and turn off the engine the remote control (key) works again in thiat moment is possible to lock and unlock the car, and also is possible to use the door control.... but when I turn on the engine again a message is shown " Airbag needs to be reviewed urgent".... also, the clock was delayed, the first time the delay was about35 minutes, the second time 2 hours 45 minutes more orless, the third time 10 minutes aprox. I think that the computer hung itself during this time.</P>
Somebody knows what could be happening and can help me?</P>
Thanks,</P>
Martin Vela</P>
</P>
</P>
</P>
Old Apr 12, 2004 | 10:54 PM
pilotsims's Avatar
all i can think of is the computer. there could be a faulty computer installed and u might need to get it replaced. ask your dealer/mechanic if you could try a new computer for awhile and see if this persist. the s60, since u say u just bought it should be under warrenty so u shouldnt have to worry about paying lots of money
Old Feb 1, 2007 | 12:15 AM
sdat1333's Avatar
Default RE: Airbag needs to be reviewed urgent S60
I dont mean to sound liek a smartass, but could it possible be the battery? Just throwing that out there as a very serious suggestion.
Old Feb 10, 2007 | 12:45 PM
Ihatespeedbumps's Avatar
Did they give you a print out of codes the car had?
Old Feb 11, 2007 | 05:57 AM
gordon368's Avatar
Everytime i went for a SRS-airbag problem everytime it was a Seatbelt and/or a SRS module- happened to me 3 times- ....that was in my s80...
atlantadriver
Apr 26, 2021 08:25 PM
gordon368
Feb 7, 2017 02:56 AM
Scott6
Sep 2, 2016 01:21 PM
ThorsHammer
Jan 5, 2012 03:52 AM
mingster
May 2, 2006 11:08 PM
