SRS - Airbag Service Urgent
Old May 2, 2006 | 09:03 PM
mingster's Avatar
Default SRS - Airbag Service Urgent
I got a dead battery and was driving on low voltage over the weekend. After the battery is replaced and I have seen this message "SRS - Airbag Service Urgent" showed up on my dash and stayed. I believe this is triggered by driving under low voltage and want to find a way to reset it before paying dealer to do it. I was unable to reset it by pressing the trip button for 15 seconds. the dash showed "26" after that and I guess that means the reset didn't succeed. Is there some kind of OBDII tool that can be used to reset this warning message? Which one would you recommend?
thanks a lot!
MC
Old May 2, 2006 | 09:36 PM
Default RE: SRS - Airbag Service Urgent
The Trip reset function is only to reset the SERVICE LIGHT.
The cost for you to buy an OBDII scanner to read the codes will way out weigh having the Dealer do it.
A scanner that can read the SRS on these cars will cost about $3000.00 or so.
Old May 2, 2006 | 11:02 PM
mingster's Avatar
wow... $3000 for a volvo SRS scan tool? The BMW OBDII tool and SRS tool that I used only run for $100+ each. In this case, definitely better to let the dealer do the work. Thanks for the information.
Old May 2, 2006 | 11:08 PM
See if you have a Volvo indy in your area.That only works on Volvo's.
Will be cheaper than the Dealer.
gordon368
Feb 7, 2017 02:56 AM
Scott6
Sep 2, 2016 01:21 PM
giannis-21
Aug 10, 2011 01:50 PM
tongzilla
Aug 25, 2008 02:24 AM
aldeener
Jul 8, 2008 09:02 PM
