How to Clean PTC on a Volvo 850
Old Apr 16, 2009 | 11:19 PM
denver005's Avatar
Default How to Clean PTC on a Volvo 850
What is the procedure to remove, clean and re-install the PTC? PTC is part of the PCV system?
Old Apr 17, 2009 | 09:53 AM
bestharry's Avatar
Take out the intake hose i.e. the one from air filter box to the turbo inlet after disconnecting the electrical connector and 2 tubings from the PTC. Now once its out, carefully remove the PTC from the hose specially taking care of the rubber gromet that holds the PTC onto the intake hose and give it a nice flush with carb cleaner or brake cleaner. You might fint the narrow hole for one of the vaccum line blocked or abstructed. The installation process is just the reverse order of removal but I actually added 2 cable ties to hold the PTC on to the hose because the gromet was not in perfect condition and have also used some black sealent between gromet and hose.
Old Apr 18, 2009 | 12:26 AM
cj351stang's Avatar
What does this PTC do???
Old Apr 19, 2009 | 12:45 AM
denver005's Avatar
Is it necessary to remove the intake hose? The PTC is clearly visible/accessible. from top.
Old Apr 19, 2009 | 01:00 AM
denver005's Avatar
Here's a link about PTC.
http://www.volvoclub.org.uk/faq/Engi...html#PTCNipple
Old Apr 19, 2009 | 09:40 AM
cj351stang's Avatar
Thanks denver005! Thats a good link.
autoxray
Jul 12, 2013 11:30 AM
91shelby
Sep 30, 2010 09:33 PM
Dah_jOkA
Jan 22, 2010 01:20 AM
denver005
Apr 19, 2009 09:42 PM
