Dipstick covered in white, milky substance?
Old Apr 17, 2009 | 10:15 PM
Saleen9090's Avatar
Exclamation Dipstick covered in white, milky substance?
I'm looking to replace the PCV because I have oild build up around the dipstick housing and puffs of white smoke from the dipstick while running a hot engine.
Now I have a milky white substance on the dipstick along with condensation. Is this a result of the bad PCV as well?
Looks bad but you guys tell me.
Old Apr 17, 2009 | 10:27 PM
nonsense619's Avatar
just means you been taking her on short trips not letting her warm up fully and the moisture is not evaporating...just take her on a nice spirited run on the highway for a while...
Old Apr 17, 2009 | 10:43 PM
Saleen9090's Avatar
But this was right after city and highway driving for about 40 minutes
Old Apr 18, 2009 | 12:36 AM
cj351stang's Avatar
Could be cause of the pcv. I would change it asap, before yu blow a rear main....
Old Apr 18, 2009 | 02:58 AM
Saleen9090's Avatar
Good news is I am using my parents car and the Volvo sits in the garage until I get the PCV. No one drives it I also found my engine serial number in order to get the right PCV system.
If anyone wants to know for future reference, there should be a white sticker on the side of the timing belt cover. It should read Se#; (number) It should be a 6-digit number between 300000 and 400000 for the '95 model
Old Apr 18, 2009 | 07:30 AM
The number is also stamped on the block on the back side like under #1 cylinder where the head meets the block.
Old Apr 18, 2009 | 04:16 PM
Saleen9090's Avatar
I've heard that to see the number on the engine you need;
1. A system of mirrors
2. Magnifying glass
3. 20/20 vision
4. Patience
I'm glad I had the sticker. Made life easier
Old Apr 18, 2009 | 09:21 PM
You can see if easy when you have time try it.
Old Apr 18, 2009 | 11:25 PM
Saleen9090's Avatar
Will do next time I am home. I think next weekend.
jasew503
Feb 6, 2014 12:15 AM
jjperko
Jul 4, 2011 08:11 AM
ScarlettL
Jan 18, 2011 09:38 PM
la verite 4l
Mar 11, 2010 07:27 AM
Dainos
Jun 8, 2009 12:02 PM
