Milky Substance on Dipstick
Old Feb 3, 2014 | 02:44 PM
jasew503's Avatar
Default Milky Substance on Dipstick
So, went to check the oil this morning (for the first time since I bought it), and noticed water droplets all the way up the dipstick shaft, and a milky/mayo type substance on the end of the dipstick. I freaked a bit, opened the oil filler cap and noticed the oil in the cam areas is normal, dirty but normal and not milky. Same with Tranny Fluid.
Checked the coolant reservoir and the coolant appears to be a perfect 50/50 mix and is green, even though the container itself look kind of stained brown.
I have taken a few short trips, (less than a mile from cold start) but have been letting it warm up for about 3-5 minutes before driving. I notice a bit of steam comes out of the exhaust and until im actually driving more than 2 miles the temp gauge never goes more than 1/3rd of the way up, but when driving on the freeway it rises but never goes above the halfway mark, so its not overheating. The heater works fine too, gets nice and hot and hasnt seemed to be losing any coolant since I bought it. Ive probably put a max of about 70 miles on it in the last 1.5 weeks, and its been pretty cold here (40'F) and in Oregon we have a lot of moisture.
Is this cause for concern?
Pictures:
Dipstick:
http://imageshack.com/a/img812/1914/liaj.jpg
Coolant Tank:
http://imageshack.com/a/img35/3100/um55.jpg
Coolant (Soaked on a paper towl):
http://imageshack.com/a/img809/3880/kf9y.jpg
EDIT: Forgot to Mention its a Turbo with approx 170K Miles, recent water pump/timing belt change within the last 1K Miles.
Old Feb 3, 2014 | 02:50 PM
No, normal aluminum motor sweet.
You do not need to let the motor warm up. However, it should go to 1/2 way and stay there so you likely have a worn thermostat.
Old Feb 3, 2014 | 03:12 PM
jasew503's Avatar
Thanks for the great response and the vids. Ive had many all-aluminum nissans and have never seen this on any of the dipsticks, so it scared the hell out of me. Thanks for the great info!
Old Feb 3, 2014 | 04:51 PM
Common scare. I have actually seen quick lube places chase people with 850's away, telling them that they had a bad head gasket and they refused to do an oil change.
Old Feb 4, 2014 | 08:07 AM
firebirdparts's Avatar
My turbo did that too, last winter. I never heard of it before I got a volvo, but it was not anything wrong with the car.
Old Feb 4, 2014 | 08:24 AM
Psaboic's Avatar
Ours has done that in the winter for the last 7 years and 75,000 miles and it has 245K on it. Perfectly normal. Take it out for a good spin (an hour or so) and let it warm up good. Most likely that will cure your issue for awhile.
Old Feb 4, 2014 | 11:50 AM
T5-Rennen's Avatar
We have five turbo Volvo's (2x850's & 3xP2's) in the family and I recall all of them seem to do this. I would love to know why this occurs. As a side note, I've had numerous alloy engines and only the Volvo engines do this
Old Feb 4, 2014 | 12:54 PM
jasew503's Avatar
I just checked my compression and its about 150 all the way across, not sure what it should be but that sounds pretty acceptable.
Old Feb 4, 2014 | 01:06 PM
Was the test done with the motor hot and WOT?
Old Feb 4, 2014 | 01:08 PM
jasew503's Avatar
No open throttle, kind of warm (I let it run only for about 3-5 minutes from complete cold in 36'F weather).
Old Feb 6, 2014 | 12:15 AM
gdog's Avatar
WOT doesn't really matter. The spec is 156 to 185 psi so as long they're fairly even it should be OK.
jjperko
Jul 4, 2011 08:11 AM
ScarlettL
Jan 18, 2011 09:38 PM
la verite 4l
Mar 11, 2010 07:27 AM
Dainos
Jun 8, 2009 12:02 PM
Saleen9090
Apr 18, 2009 11:25 PM
