Climate Control Bulbs not flashing when angine strated
Old Jun 24, 2009 | 09:33 AM
jikispqr's Avatar
Default Climate Control Bulbs not flashing when angine strated
As i read from the manual, the CC (Climate Control) system bulbs should flash for about 20 seconds when car is started.
It is about a month my car is failing to do so. There are days when it is flashing and there are days when it just lights up and is on.
What can be the problem?
I checked the freon, and it is normal
thank you in advance for your advice
Old Jun 24, 2009 | 10:29 AM
850tony's Avatar
they should not flash...
Old Jun 25, 2009 | 02:04 AM
jikispqr's Avatar
but in the manual of my 1995 T5 wagon, it is said, that they should flash for about 20 seconds when the car is started and it means that self diagnostics of CC electric system is on.
an if the system will fail to flash it means that some problem has occurred in the Climate Control system
Old Jun 25, 2009 | 11:48 AM
850tony's Avatar
as far as i am aware they only flash when there IS a problem.
Old Jun 26, 2009 | 08:03 AM
Psaboic's Avatar
Yes, they only flash when there is a problem
Old Jun 26, 2009 | 01:16 PM
850tony's Avatar
re0read the manual. and/or scan it in and show us.
Old Jun 27, 2009 | 06:43 PM
turbo850wagon's Avatar
the only time i have ever seen a CCM flash the lights is when there is a problem
Old Jun 27, 2009 | 07:04 PM
nonsense619's Avatar
double check manual...if it says they should blink then i suggest you use white-out.
Old Jul 3, 2009 | 02:24 AM
jikispqr's Avatar
Default Miracle :)))
sorry guys, I read the manual and got the wrong interpretation.
Thank you.
I thought flashing was normal because it was flashing for almost nine months since I bought my 850 wagon 1995. (the millage was 47000 only)
It stopped flashing about two weeks ago and i thought that was the problem ))
so i read the manual and as I already was thinking that "not flashing" was a problem I misunderstood the clause from the manual ))
thanks again.
and here comes next question:
It is about two weeks that ACC system is not flashing and I do not have to press the shift locker to move the gear selector )
can anyone tell me what happened to my car? It kind of cured itself ? )))
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
autosuppliesdirect
Aug 24, 2013 02:19 PM
chad_m
Jan 17, 2012 12:00 PM
sly_fox
Mar 14, 2011 02:28 AM
panopticon
Mar 21, 2005 09:38 PM
