How to disconnect heater Hoses
Old Oct 12, 2009 | 03:28 PM
HeaterReplacement850's Avatar
Default How to disconnect heater Hoses
I have a 1994 Volvo 850 with a leaking heater core. I've been able to get to the heater core, but having difficulty figuring out how to disconnect the "quick disconnect" heater hose. Can some one help me?
Do I disconnect the heater hoses at the firewall inside the engine compartment or under the dash? I know they are supposed to be quick disconnect, but can figure out exactly how to disconnect them.
thanks Ed
Old Oct 12, 2009 | 03:35 PM
Unhook under the dash.
There should be a screw going from the front through the plastic box into the pipes.
Old Oct 12, 2009 | 03:55 PM
Default Screw in the white box holding the heater core?
do you mean the white box holding the heater core?
I can feel something between the two tubes that go from the firewall to White box, However, I can't see exactly what this is because the brake and gas pedals are in the way. Given the location, not sure how I could access it.
thanks
Old Oct 12, 2009 | 04:09 PM
Look in there with a Mirror.
The screw usually goes into the bottom plastic section of the heater core. The screw will go from the back of the car towards the front.
Old Oct 12, 2009 | 05:38 PM
Default got it, but new question
Okay, got the screw out and pulled out the heater core. thank you, I couldn't have done it without your help. I really appreciate it.
now for the new question, I'm told I'll new a set of o rings, There seems to be some rubber on the tubes that connected to the heater core. Is that rubber the old o rings? Should I remove that rubber? and put on the new o rings? I suspect yes, but don't want to damage the tubes if that rubber is supposed to be there. thanks Ed.
Old Oct 12, 2009 | 05:44 PM
Yes replace the o-rings. They go around the pipe where it slides into the heater core.
johnnyb_s
Dec 14, 2018 01:52 AM
mikde
Jan 21, 2014 01:12 PM
Pikngrn
Sep 5, 2012 08:38 AM
kelmar
Penta
Jan 14, 2010 03:44 PM
montysano
Apr 27, 2008 07:25 PM
