2008 XC70 Oil Filter Removal
Old Oct 29, 2009 | 05:08 AM
teising's Avatar
Default 2008 XC70 Oil Filter Removal
It seems that the oil filter element sits in a small bowl that is accessible from the top of the engine. There is a plastic cover on the bowl with a plastic nut molded into the top of the cover. The plastic nut molding looks like a 36mm. For plastic filter housing cover removal, it seems like it is easist to use a 36mm socket with an extension since there is not much room to work.
QUESTION: once the filter housing cover is off, do I pull the old filter element out of the top of the engine or drop it down below to remover it?
How much oil to put in the bowl once the new filter element is dropped in?
Last edited by teising; Nov 4, 2009 at 02:26 AM. Reason: change from 32mm to 36mm socket
rolling2
2001-2013 model year XC70
Oct 2, 2014 01:45 PM
volvoC70GA
Oct 12, 2013 06:06 PM
RalphsRadio
Dec 30, 2010 11:46 AM
mikebrooks
Jul 18, 2010 06:01 AM
profcharlie
Sep 27, 2006 11:58 AM
