Throttle body cleaning instructions needed
Old Nov 4, 2009 | 08:31 AM
Psaboic's Avatar
Default Throttle body cleaning instructions needed
Can someone give me directions on how to clean the throttle body on a 2001 XC-70? I tried a search and nothing came up. I'm sure it has been done. Also, outside of a throttle body gasket, what other parts might I need? Thanks,
Glenn
Old Nov 4, 2009 | 08:37 PM
It is not all that bad. Remove the intercooler hose from the intercooler and throttle body. The throttle body side is a pain most of the time. There is a few sensors and a hose in the pipe you need to remove.
Then unplug the throttle body. The plug is mounted to the engine harness like by the engine mount. If it has never been off the wire will run behind the starter to block bracket. Then remove the throttle body from the intake and clean it.
treestone27
Apr 29, 2014 07:40 AM
go2sharks
Jan 21, 2009 10:24 PM
mturner333
Oct 18, 2005 09:21 PM
DanR
Sep 7, 2005 02:31 AM
proudmonkey
Jul 21, 2005 10:01 PM
