v40 tranny gasket
Old Nov 10, 2009 | 02:17 PM
Malador's Avatar
Default v40 tranny gasket
Any one know if the gasket on the trannsmission is going to be reusable? or do need to pick up some permatex? the local parts shop doesn't list a filter or gasket for my car. 2000 v40
Old Nov 10, 2009 | 03:55 PM
AutoNaut's Avatar
What are you doing, changing the fluid and filter?
The I am not sure which transmission you have. Some use a synthetic fluid and it is important that you get the correct stuff. I don't believe that they have a filter.
According to VADIS:
The AW50-42 Use only automatic gearbox fluid (ATF) which fulfills both Dexron II E and Ford Mercon standards.
The AW55-50 Use only automatic gearbox fluid, Volvo P/N 1161540-8 may be used.
Stan
Old Nov 10, 2009 | 06:20 PM
Malador's Avatar
According to VADIS:
Stan
I am just planning on changing the fluid. I assume you have to drop the pan do so, although i haven’t looked under the car yet. The current fluid is brown.
The owners manual said to use Dextron III, so dino must ok with mine, Unless a technical service bulletin came out.
thanks
Old Nov 10, 2009 | 08:24 PM
MN2.5T's Avatar
For a drain and fill there is no need to drop the tranny pan, just remove the drain plug. There is no filter.
However, the best option is to flush the tranny. A drain and fill will only exchange about 1/4 of the fluid. Vadis outlines a simple way to flush the tranny using the transmission pump. If you don't have access to Vadis, check the s40concepts.net web site. Search the "How-to" section for really good complete step-by-step instructions with pictures.
I recently did a flush on my S40 - very easy to do. Tranny was not giving any problems - I just did it because the fluid was dark. 8 quarts of Dexron IV is cheap insurance.
Old Nov 10, 2009 | 09:16 PM
Malador's Avatar
Dextron 6 right? thanks for the info. That is a awsome how-to!
Old Nov 10, 2009 | 10:34 PM
AutoNaut's Avatar
Default 2000 Transmission Fluid Change
This may help.
Stan
Attached Thumbnails v40 tranny gasket-2000_s-v40_aw50-42_transfluid_change_page_1.jpg   v40 tranny gasket-2000_s-v40_aw50-42_transfluid_change_page_2.jpg   v40 tranny gasket-2000_s-v40_aw50-42_transfluid_change_page_3.jpg
Old Nov 11, 2009 | 09:08 PM
MN2.5T's Avatar
Originally Posted by Malador
Dextron 6 right? thanks for t/he info. That is a awsome how-to!
IV is 4. ie: Dexron 4. Don't think they have a Dexron 6 yet. One tip: Cover the floor area with a thick layer of newspapers. You are bound to spill some fluid somewhere in the process!
Old Nov 11, 2009 | 10:44 PM
Malador's Avatar
Dextron 6 has been out for a three for four years now. I remember putting a lot of that stuff in hmmwv back when i was still in the military. It's supposed to be backwards compatible, but I've run of some subaru owners that swear that stuff causes all sorts of problems in their trannies.
Thanks for the tip about the news papers
Block91
2001-2013 model year V70
23
Apr 3, 2020 09:53 PM
GrantRobertson
Jul 2, 2013 01:49 AM
mandobizar
Apr 22, 2011 01:22 PM
Garon
Apr 22, 2009 02:57 PM
shpeedy
Sep 26, 2006 08:08 PM
