2004.5+ S40/V50 DTC Easter Egg
Old Nov 11, 2009 | 12:34 PM
AutoNaut's Avatar
Default 2004.5+ S40/V50 DTC Easter Egg
I found this a while back but folks have had mixed success. It may depend on the year of your car and what software is installed.
This little Easter Egg can tell you if you have any DTC's stored. Unfortunately, it does not give the actual code.
1) Turn your ignition to II, but don't start the car.
2) Hold the "read" button on your turn signal stalk
BE QUICK HERE, timing is everything
3) Press the rear foglight switch twice.
4) Look at your trip comp.
5) Keep pressing "read"
After a short pause, the display (hopefully! ) reports:
No DTCs found.
Reported systems are:
BCM (Brake Control Module)
DEM (Differential Electronics Module - AWD)
ECM (Engine Control Module)
SWM (Steering Wheel Module) (probably only if DSTC)
EPS (Electrical Power Steering)
CEM (Central Electronic Module)
SRS (Supplemental Restraint System)
CCM (Climate Control Module)
DDM (Driver Door Module)
ICM (Infotainment Control Module)
PDM (Passenger Door Module)
KDM (Keyless drive module)
Enjoy
Stan
I know I posted this in the S40 section too, but someone has to keep the V50 section alive.
Old Nov 11, 2009 | 07:54 PM
imhereftw's Avatar
Thumbs up
Nice, this could come in handy, wonder if it works for other models/years.
JAMML
Oct 7, 2010 10:01 AM
Somthngfrce
Apr 6, 2010 03:12 AM
AutoNaut
Nov 11, 2009 12:32 PM
Somthngfrce
Apr 21, 2009 04:49 PM
tech
Mar 23, 2008 08:38 PM
