Engine cuts out
Old Nov 12, 2009 | 08:15 PM
Joe L's Avatar
Default Engine cuts out
Ok, so I have a 94 850 turbo. The car cuts out when the car shifts from first to second gear (auto trans) From what I can tell on the boost gauge, it sits at about 90% in first gear, then when it changes to second the gauge goes to the end and the car cuts out. From what I've read on here it could be a fuel cut off from a boost spike...? What causes that? Where do I start?
Also the car seems to be getting really bad gas mileage. I do drive short distances, like less than 5 miles to work...I know that can contribute to poor mileage, but this seems excesive. When I first got the car about a month ago the mileage readout said an average of 24 mpg....it now reads 19. Since I bought the car I've done a full tune up including plugs, wires, cap, rotor, and air filter...I have yet to change the fuel filter though. Also the only codes I get are a knock sensor code.
I've also read that I should replace the PCV system, as I have oil under the cover on the top of the engine..looks to be coming from the oil cap. I did pull the dipstick out while the engine is running and see a tiny bit of smoke coming out....It seems this can cause poor fuel mileage...? Not sure how though...pressure inside the block working against the pistons? Sorry for all the questions, I'm a total noon to Volvos and also Turbos haha Go easy
Thanks for any help, Joe
Old Nov 13, 2009 | 06:22 PM
Joe L's Avatar
Bump No ideas?
Old Nov 14, 2009 | 07:27 PM
Joe L's Avatar
Dang, no one wants to help out a noob!?
paradigmcubed
Dec 30, 2021 02:27 PM
violetta
Mar 28, 2011 04:22 PM
jtchipin
Jan 11, 2010 10:34 AM
Dosti
Aug 11, 2009 04:33 AM
JeremyR
Aug 3, 2006 05:36 PM
