Check Engine light with P2190 / P2188 codes...
Old Nov 15, 2009 | 12:47 AM
q2quest's Avatar
Default Check Engine light with P2190 / P2188 codes...
My 2004 T6 has been idling erratically and often dying when I come to a stop. It will usually restart, but will die if I don't keep jazzing the throttle. The check engine light came on and I pulled the above codes with a scanner. Has anyone else had this problem? It runs fine off idle. Thanks
Old Dec 17, 2009 | 01:22 PM
ehodges05's Avatar
Thumbs up
you may have already gotten this resolved, but it's your air filter.. i did an air filter flush, which basically alleviated it for a couple of months, then just replaced my air filter today.
Old Oct 11, 2010 | 02:34 PM
Marcus/NaSonya's Avatar
Default p2190/2188
I am having the same problem, I am going try your suggestion and let no know my results. thanks
Old Jan 5, 2011 | 06:42 PM
bradnight's Avatar
I have the same problem, did replacing the air filter work?
Old Jan 6, 2011 | 09:06 AM
ehodges05's Avatar
yes, the "flush" actually worked for 3/4 months, and then the air filter for a month.. eventually i had to take it in to be worked on, but i would definitely try those before doing anything else..
Old Apr 9, 2011 | 04:35 PM
jaredkeel's Avatar
im kinda having this same porblem. what do you mean by "flush"?
Old Oct 27, 2012 | 07:20 PM
olisaeloka's Avatar
Yes, What is meant by "flush?"
bvallese
Oct 6, 2013 08:51 PM
alpac
Jan 16, 2012 10:10 AM
jaredkeel
Apr 11, 2011 06:37 PM
samloz
Nov 27, 2008 12:34 AM
gabyman97596
May 14, 2007 09:52 PM
