TCP releases new 850 parts
Old Nov 16, 2009 | 06:37 PM
TCP Productions's Avatar
Default TCP has now released new parts!
TCP Productions will be releasing new parts this Friday.
The most exciting one (for us anyways) is a replacement throttle plate without the air wedge on it. For those of you who don’t know the stock 850 throttle plate has a wedge on it; this wedge blocks airflow, and makes for a slower start from idle. With our new designed throttle plate you will now get greater throttle response, better take off, and a slight increase in acceleration. Install time is less than 30 min, and all you need is your basic tools. GREAT modification for any Volvo 850.
The other great advancement we will be releasing is a windshield wiper repair kit. Who has issues with their driver side windshield wiper not whipping all the way? Well now TCP Productions has the fix for you. What our kit does is rotates the wiper assembly tighter into the windshield adding the extra force needed to complete a full wipe. Don’t spend the money on a Volvo replacement wiper arm when it usually doesn’t fix the issue, install our kit and make things right. Install time is roughly 15-30 min; kit includes multiple positions of added force.
Please feel free to ask any questions or send us a PM.
Old Nov 16, 2009 | 06:48 PM
Nice, definitely going to get that throttle plate.
Now, how about that heat shield?
Old Nov 16, 2009 | 06:56 PM
We currently have 4 or 5 different variations of the heat shield. working on the best fitment, installation, and universalized (non-turbo and turbo). Soon to come, along with some other parts.
Old Nov 16, 2009 | 07:13 PM
Awesome. That will help me out in my whole wagon build.
Old Nov 16, 2009 | 07:31 PM
gdog's Avatar
I thought the Throttle Plate mod only applied to the N/A 850?
As seen here:
http://www.matthewsvolvosite.com/for...62a49c86a51327
and here:
http://volvospeed.com/vs_forum/index...6#entry1168946
So are you guys selling the Volvo 960 throttle plate or did you manufacture your own?
Old Nov 16, 2009 | 07:35 PM
We have manufactured our own. The plate we will be selling is 65mm (which is the non-turbo throttle body).
Old Nov 16, 2009 | 07:36 PM
He made his own. You cannot simply remove the plastic piece in the turbo TB because that will leave two little holes, allowing for air to pass and screwing up your idle.
Will the plate still fit inside the turbo TB?
Old Nov 16, 2009 | 07:42 PM
The turbo throttle body is 60mm, its in the works.
Old Nov 16, 2009 | 11:23 PM
denver005's Avatar
Can you send the link to the wiper kit?
Old Nov 16, 2009 | 11:43 PM
Currently the wiper kit is not yet in full production yet. Just today we started the mass production of the kit.
Come thursday or friday the kit will be available for purchase.
Old Nov 20, 2009 | 02:41 PM
NEW PARTS ARE NOW RELEASED AND ON THE WEB!
Many of you have been waiting, and now they are here. YEP that's right. the new parts listed above are now ready for purchase.
Feel free to check our the new volvo 850 parts here
And as always, dont forget your 10% off cupon.
cupon code: VFrocks
Old Nov 20, 2009 | 03:28 PM
The TP is only for NAs correct?
Old Nov 20, 2009 | 08:33 PM
Correct. shortly we will have a turbo one, no worry's.
Old Nov 21, 2009 | 08:56 AM
denver005's Avatar
Has anyone tried this kit? If yes, please post a review.
Volvo 850 windshield wiper repair kit
Old Nov 21, 2009 | 01:22 PM
850tony's Avatar
i am runing it on my two 850's currently. i like the results, and the interchangability of the shims. being that they are different thickness's on one car i had to use the large shim and the small shim. but the other 850 i used the large shim and the medium shim.
great kit.
Old Apr 24, 2010 | 01:22 PM
850forum's Avatar
I don't have a problem with the getting a complete arch of motion. But I can't get the blade to stay on the glass all the way; it comes off the glass in the last third of the arc. I have been unable to bend it to get it to stay down.
Old Aug 9, 2010 | 10:00 PM
TacklaNHL's Avatar
I am getting the same thing... it not staying all the way on the glass. I would stop bending anything... these things aren't bending... it's the rubber bushing at the base is cracked and weak and not holding the force at the top of the arc... it's a $6 rubber nub at the dealer.
Or... you could use a tightening, or a shim... I would think... but I've got the nub on order from my dealer... should know in a couple days.
Old Aug 15, 2010 | 11:39 PM
air force rascal's Avatar
I don't think the Turbo Model has a WEDGE on the Throttle Plate,,only on NA's...also, I fixed my Throttle plate by just taking off the wedge and pluged up the holes J B Weld and snaded it down..works just fine for only less then 5.00....
angryboys604
Mar 14, 2014 03:45 PM
TCP Productions
Nov 27, 2009 07:59 AM
boxpin
Nov 20, 2009 02:42 PM
TCP Productions
Oct 31, 2009 08:29 AM
squeezy
May 26, 2008 11:22 PM
