Brake Hose Spring Clip Removal
Old Aug 15, 2010 | 08:50 PM
vjaneczko's Avatar
Default Brake Hose Spring Clip Removal
How do I remove this spring clip from the brake hose? I can’t find any information about how to do it, and I can’t find them for sale – so I’m not going to risk breaking them.
I assume that the flexible hose connector is running through the bracket and that the bracket has a hex-shaped hole in it to keep the hose from twisting loose – right?
Attached Thumbnails Brake Hose Spring Clip Removal-brake-hose-spring-clip.jpg
Old Aug 16, 2010 | 12:01 AM
gdog's Avatar
The clip just holds the flex line taught against the steel bracket. You would have to disassemble to remove the clip, by unthreading the flare nut (on the hard steel line) from the flex (rubber) line.
pierremcalpine
Jul 3, 2014 07:54 AM
darylabrams
Dec 25, 2010 06:53 PM
blackstarpower
Jan 5, 2007 12:26 AM
blackstarpower
Dec 31, 2006 09:19 PM
ricecooker
May 26, 2006 05:37 PM
