Not quite a misfire....
Old Nov 18, 2009 | 01:53 PM
MN740GL's Avatar
Default Not quite a misfire....
I have a 98 V70XC with the 2.4L 5cyl Turbo engine. It has a mis-fire, but it doesn't. At idle or in drive it feels like it has little power and almost like one cylinder isn't firing (does NOT trip the CEL or throw any codes) but in reverse, it runs smooth and has a lot of power.... New Plugs, Wires, Cap, Rotor, and some vacuum lines. I have checked all over the engine for a vacuum leak with brake cleaner and have found none. I haven't checked the turbo yet, but it's suspect because of the small cloud of blue behind the car in the morning (i have a spare turbo I hope to swap in this weekend) I am also borrowing the compression tester from my Step-Dad to check all 5 cylinders. Is there a way to check the injectors before I pull them? So far, this car has been a basket case, if it weren't for the AWD and safety, I might be tempted to trade it off.... Does anyone have any ideas or similiar problems?
Old Nov 18, 2009 | 09:47 PM
MN740GL's Avatar
Is it possible that one of the charge tubes or the intake (cheap flimsy plastic type) hose form the intake box to the turbo has a crack in it? Seems logical that it runs good in reverse, but when the car is in drive or neutral (Engine tilted the other way) it runs poor? New injectors and rear o2 sensor tonight. No difference.
Old Nov 19, 2009 | 12:04 PM
Psaboic's Avatar
Very possible. Have you checked the coil as well?
Old Nov 20, 2009 | 12:58 PM
MN740GL's Avatar
Single coil on this model. If it wasn't working, wouldn't I have no spark what-so-ever?
Old Nov 23, 2009 | 07:24 PM
Psaboic's Avatar
Yep. Sorry, I thought it might have been a multi coil model. HOwever, if the coil is weak you will have weak spark
piv15
Mar 6, 2013 10:02 PM
glitchd
Mar 8, 2012 04:26 AM
Tye1
Sep 14, 2011 05:13 PM
ChrisAce
Jul 10, 2009 10:39 AM
