01 S60 2.5T has air leak sound inside
Old Nov 18, 2009 | 06:27 PM
CASS60's Avatar
Default 01 S60 2.4T has air leak sound inside
It sounds like air is escaping out of the left upper vent of my dash. When I engage the brake it immediately quits. It soulds like something is moving behind the radio/heat/air panel that may be opening or closing this air flow.
Does this make any sense to anyone? I thought there was a thread on something like this before, but I cannot find it.
Any help would be much appreciated.
Old Nov 18, 2009 | 07:41 PM
Bender's Avatar
no such thing as a 01 2.5t :P (i think you mean 2.4t!)
that said since it is stopping as soon as you hit the brakes it is probably your brake booster (fairly common failure) BUT check around your pedals it may be a loose rubber seal.
Old Nov 19, 2009 | 01:32 PM
CASS60's Avatar
Thanks for your imput. If there is a failure with the brake booster, why would it make that noise? Is air actually escaping?
I corrected my title since I am not sure why I put the 5. At any rate, I already am a girl and I don't know much about cars, so stating my car as a model that doesn't exist is NOT helping my case!
Old Nov 21, 2009 | 02:16 AM
Nataku's Avatar
My brake booster is on it's way out and there is a hissing sound that goes away when I depress the brake pedal. It's gotten worse now (now it's a high-pitched whine), but I can't afford the $500 for a new brake booster at the moment....
Old Nov 23, 2009 | 06:31 AM
Bender's Avatar
haha no problem Cass - yes when your brake booster fails, air (albeit a tiny amount) is escaping the vacuum system.
Check those rubber gaskets first, because they have been known to come loose frequently (and the fix is FREE and nothing to worry about!).
Old Nov 25, 2009 | 06:45 PM
CASS60's Avatar
Thanks. Good advice. It is obnoxious and people riding with me think my car has ghosts or is a big pile of crap and I do not appreciate that!
ETA: I apparently don't know how to edit the thread title. Sorry.
allenzachary
Dec 8, 2011 10:20 AM
joefloresvolvoforums
Dec 24, 2010 01:21 AM
scottp
Sep 28, 2010 12:35 PM
kartman01
Nov 30, 2005 10:00 PM
bongo240
Jun 10, 2004 12:31 AM
