ac problems new compressor and still no good
Old Jul 15, 2010 | 07:18 PM
elimont's Avatar
Default ac problems new compressor and still no good
I had the compressor changed in the car since the shop said it needed changed. It most likely only need to be shimmed but they couldnt understand that and I had no time. After the compressor was changed it worked fine for about 2 weeks now it wont work at all. They checked pressures and switches but can fine nothing wrong. What should I look at they may be missing?
Old Jul 16, 2010 | 06:26 PM
Dealer_Tech's Avatar
Does it turn on at all or does it intermitently turn off? Need more info to help the best I can.
Old Jul 16, 2010 | 07:31 PM
elimont's Avatar
I am out of town and not near car. Going on what wife and shop told her. Compressor is running, but only blows hot air. they checked freon and pressure switches. I will be able to look at car next weekend just looking for a few leads to start with beyond the normal freon and clutch issues. Maybe little volvo normal problems a non volvo shop might miss.
Old Jul 23, 2010 | 06:08 PM
elimont's Avatar
took a look at the car. the clutch is running but makes some noise when running. more noise than i think it use to make. the ac turned on and on either auto or not it blows hot air not warm air but hot air.
86volvoguy
Apr 20, 2017 10:50 PM
Oshawaman
Apr 21, 2012 07:32 AM
rikkiflores
Aug 11, 2011 03:23 PM
jadler
Aug 1, 2011 03:25 AM
gnewton
Jun 26, 2010 09:53 PM
