PNP switch replacement
Old Aug 2, 2010 | 04:52 PM
SJanas0993's Avatar
Default PNP switch replacement
I think my transmission problem (getting stuck in 1st gear when the engine is cold) may be due to a faulty PNP switch. Note that when I rapidly move the shift lever back and forth numerous times, it seems to relieve the problem temporarily. I have read the article on volvospeed.com/Bay13 about replacing it and it refers to an "alignment tool". Anyone know what this is and where it can be bought?
Old Aug 3, 2010 | 12:25 PM
TacklaNHL's Avatar
Yep.
I did a couple years ago. That was the exact problem I ran into too. Getting stuck when it's cold. But eventually, it wouldn't allow me to switch gears.
It's SO EASY!
The PNP switch is located under the airbox/battery area. Take the airbox and battery out (2 easy things to do) and you'll see it there.
Here's the tutorial (which you've found, but i'm linking for others)...
http://www.volvospeed.com/Repair/pnpswitch.php
You don't need an alignment tool... I did without and it's pretty easy to figure out how it goes in.
FCP sells the part for $85 for "ScanTech" or $165 for genuine Volvo. I think I went with the scantech one to try and save the money... and it's been great since then.
Old Aug 4, 2010 | 10:18 AM
SJanas0993's Avatar
Default Thank you
Many thanks! I hope it solves my problem. I ordered the ScanTech switch as well.
Regards
Old Aug 4, 2010 | 11:52 AM
SJanas0993's Avatar
Default One more question
One question for TacklaNHL. Did you also experience that the car would sometimes only start from a standing position in a higher gear (3rd?). That happens to me and after I turn off the ignition and wait for a minute or two, it starts in 1st fine. Just trying to do my best to make sure it is the PNP switch.
Old Aug 4, 2010 | 03:59 PM
TacklaNHL's Avatar
Well, I didn't notice that... but I did notice something similar... it would be fine if I set it to winter-mode (which is the same thing... starts in 3rd gear).
With the PNP switch swap... you should be good to go.
Old Aug 11, 2010 | 08:31 AM
SJanas0993's Avatar
Default Alignment question
TacklaNHL or anyone who has done this PNP switch replacement: Got the new switch and I am getting ready to tackle this job. TacklaNHL, can you give me a quick explanation of how you aligned the switch without the alignment tool? I have been looking at posts on this and one involves looking at the reverse lights going on and off, but I have no reverse lights (I think this could be related to the faulty PNP switch). Another post mentions a makeshift tool using washers and some steel plates, but I can't really understand the explanation. It doesn't sound like it should be a big deal, I just want to make sure I know how to do it before getting started.
Thanks to anyone who responds!!!
SJanas0993
Old Aug 11, 2010 | 11:05 AM
TacklaNHL's Avatar
I didn't use any tool. I just put it in as the old one came out. It was too easy.
Old Aug 11, 2010 | 11:16 AM
SJanas0993's Avatar
OK. Thanks again!
Old Aug 11, 2010 | 11:41 AM
vjaneczko's Avatar
Have you seen this post over at MVS?
http://www.matthewsvolvosite.com/for...hp?f=1&t=29930
It's actually split into two posts, and you'll want to focus on the second one. Maybe it'll help!
Old Dec 2, 2012 | 10:21 PM
Bucker's Avatar
Default Old Thread, same problem
Hey, I believe my 98 V70 T5 is acting up with the same symptoms as previously mentioned.
I clicked the link, and I can't find the article on how to change this PNP Switch.
Any new links or information would be great if it's out there. I've only owned this car for 6 months, bought it with 196,000k, it's now got 204. It seems to be thinking it's in W or Winter Mode when it's actually on E - Economy.
Thanks!
Bucker
rspi
Mar 2, 2014 04:08 PM
960 rookie
Dec 30, 2010 03:19 PM
rich850
Aug 30, 2006 08:13 PM
waldos960
Jan 3, 2006 09:01 PM
tipp80
Jul 20, 2005 05:31 PM
