Heater issues
Old Aug 4, 2010 | 08:23 AM
rgreen4's Avatar
Default Heater issues
98 V70 AWD 198k. When I place the CC setting to anything past ice cold say 64 degrees I keep getting an antifreeze odor in the car. I must have a leak somewhere in the CC sys because I have to keep adding coolant if I have been using any setting other than ice cold. I suspect the heater core. Has anyone had this problem and could there be any other component that is the culprit other than the core. Also any tips on removing the core would be helpful
Old Aug 6, 2010 | 07:31 AM
Georgeandkira's Avatar
Default Core
Hello, Replacement procedure for heater core replacement is on one of these boards (Bay 13 or Brickboard). Sorry for that incomplete answer. They say it's straightforward. I have read several posts which claimed to have done this job in 2 hours or less. Do not give in to the temptation to add "stop leak" to your cooling system. Kira
Old Aug 6, 2010 | 10:50 PM
gdog's Avatar
Ck the carpet for being wet from leaking coolant.
Here's the write up.
http://volvospeed.com/vs_forum/index...core-install/?
ycartf
May 6, 2013 11:19 AM
Vantucky
Jan 9, 2013 12:56 AM
newvolvogirl
Nov 14, 2012 06:38 PM
RichardKile
Dec 15, 2010 07:23 AM
easilyamused
Feb 2, 2010 10:09 PM
