Brake pedal air release?
Old Aug 7, 2010 | 08:13 AM
howardr's Avatar
Default Brake pedal air release?
When I release the brake pedal, I hear a squeak, and what sounds like a release of air. Has anyone experienced this before?
The vehicle is a 2002 S80 T6. 116K miles.
I had the timing belt done last year, the power steering pump, and the alternator. That's it.
This is a great car and I would recommend it to anyone. It's my second one.
Thanks for anyone's help.
Old Aug 13, 2010 | 11:26 AM
joshka89's Avatar
I get the same issue. It's been doing it for a long time now and hasn't seemed to affect anything at all. I think it is the small pneumatic pump that controls the smoothness of the pedal.
The pneumo pumps on my trunk door do the same thing when I open it up all the way but there's no problems.
Old Sep 7, 2010 | 03:53 PM
jonclayton1985's Avatar
sometimes on mine I have a constant hissing coming from the brake pedel. sometimes i just have to give the pedal a little tap and it goes away, and sometimes it doesn't. It doesnt seem to effect the braking performance, but it does scary the hell out of my girlfriend. what could the cause of it be?
Old Sep 8, 2010 | 12:12 AM
nicolaselias's Avatar
In all likelihood your brake booster is dying...
Its probably fine to use as it is, but eventually you will have to change it.. Its a common problem and there is a sticky..
On the other hand, mine has been behaving just like yours for about 3 yrs now and hasnt gotten any worse
Old Sep 8, 2010 | 06:28 PM
I'm not too worried about it, but every now and then the pedel get really stiff. This typically only happens right after start up, once everything heats up it goes back to normal.
Old Sep 8, 2010 | 08:40 PM
Sounds like bad brake booster to me. Eventually all brake assist will stop and the pedal will be hard at all times.
Old May 23, 2011 | 06:35 PM
RJKIRKJR's Avatar
Had mine done in 2010...500 for part 700 labor...!!!!
Old Jun 3, 2011 | 12:41 PM
brobabs80's Avatar
Default Booster Pump and diaphram is going bad
yep - look here: https://volvoforums.com/forum/volvo-...ars-off-43983/
and here: https://volvoforums.com/forum/volvo-...lacement-6988/
skamil
Sep 2, 2021 08:44 AM
nmikmik
Sep 17, 2012 10:42 PM
stunna7516
Jun 16, 2011 10:43 AM
DIYinCT
Aug 4, 2009 03:18 PM
cruzcountryxc70
Engine & Internal
Apr 28, 2008 05:42 PM
