2001 v70 t5 - front passenger strut mount washer
Old Aug 26, 2010 | 07:40 PM
Roadwarrior's Avatar
Default 2001 v70 t5 - front passenger strut mount washer
Just had my struts replaced but the mechanic did not change the strut mounts. The front passenger upper strut mounts failed on me in the middle of the desert. Had to go to a local desert mechanic and he is having trouble ordering the final pieces. I ordered new strut mounts, bushings, and bearings but I need to replace the strut mount washer, fitting, lock, and cap ... It's the rubber washer and etc that is on the very top before the final nut. Already spent too much $$$. Where can I order this online/phone?!?? HELP!!! Need to get back on the road. Much appreciated in advance ....
Old Aug 26, 2010 | 08:34 PM
SVTfocusO3's Avatar
http://www.autopartswarehouse.com/se...+Components%29
I don't think there are too many parts, you can't get back on the road with the stuff you had already on there? That 4-spoke nut holds it all together.
Old Aug 26, 2010 | 08:52 PM
Default Unfortunately those parts are now missing...
Unfortunately no. The washer broke off when I was on some dirt road. I could not see the part of the strut sticking out on top! Essentially the tire was attached only on the bottom! And it seems the mechanic DID NOT use a proper nut when he replaced my strut!
Old Aug 26, 2010 | 09:22 PM
I looked at the link and I don't see the washer piece. I already ordered the bushing. I need the rubber washer and goes on top of the strut bearing before you screw the last bolt on. It looks like a o-ring gasket but has 'Volvo' on it.
Old Aug 26, 2010 | 09:25 PM
SVTfocusO3's Avatar
Yeah, I know what your talking about, let me do some looking around our shop and I will let you know what I find.
Old Aug 26, 2010 | 09:38 PM
Thanks for looking. Got to love the good samaritans on this board. You're a life saver!!
Old Aug 26, 2010 | 09:51 PM
SVTfocusO3's Avatar
You need number 2?
Old Aug 26, 2010 | 10:00 PM
1, 2, 3, and 23.
Old Aug 26, 2010 | 10:08 PM
SVTfocusO3's Avatar
ok...
Old Aug 26, 2010 | 10:26 PM
Is part 23 necessary?
Old Aug 27, 2010 | 09:44 AM
SVTfocusO3's Avatar
Not really.
Old Aug 27, 2010 | 10:22 AM
What do I need to get to get back on the road? There will be dirt road driving so nothing mcguyver.
Chappy
Dec 17, 2014 08:50 AM
nhadoulis
Mar 2, 2014 10:03 PM
slimflex2
Feb 26, 2012 06:50 PM
go2sharks
Jan 22, 2011 09:11 PM
Hugh G Rection
Jul 1, 2007 02:42 PM
