car won't down shift (passing gear)
Old Sep 5, 2010 | 05:20 PM
volvoQ's's Avatar
Default car won't down shift (passing gear)
1990 740 volvo turbo.
I notice the car won't downshift when I get on the throttle, it will go back down through the gears when coasting to a stoplight, but the "passing gear" doesn't feel like it's there... I checked the trans fluid and it was full and didn't smell burned... any ideas on this one? perhaps a solenoid or plug somewhere? Also, the rpm's don't go up past 3000 or so when I stand on it.
Thanks!
Old Sep 6, 2010 | 11:27 PM
volvoguy2323's Avatar
Banned
Originally Posted by volvoQ's
volvo turbo.
Thanks!
Sounds like either your kickdown cable is,rusted stuck, broken or not adjusted properly. Check that first
Old Sep 7, 2010 | 02:26 AM
Typhoon's Avatar
I agree. Should spin to 5500 at full throttle. I adjust the kickdown cable so I just feel the detent (hard spot) in the kickdown cable as the accelerator pedal goes to the end of it's travel.
Regards, Andrew.
Gilles
2001-2013 model year V70
Apr 8, 2013 09:24 PM
pro36
Mar 30, 2010 10:56 AM
UnDeR EsTiMaTeD
Sep 27, 2004 12:02 PM
