Reverse lights on 87 wagon
Old Aug 27, 2004 | 04:41 PM
devon's Avatar
Default Reverse lights on 87 wagon
I have an 87 740 GLE and the reverse lights are not working. I've checked fuses with no avail. Where is the reverse light located?
Has anyone else had this problem? What was your fix?
Thanks!
Old Aug 27, 2004 | 09:40 PM
TheVolvoMan's Avatar
Default RE: Reverse lights on 87 wagon
Devon,
I would take the bulbs out of their sockets in the rear, then use sharp knife and scrape off the lead on the bulbs, to make sure you have good contacts. In case you have not done so, under the cigarett lighter, you need to pool the fuse panel out, where you will see the the diagram for each fuse.
good luck
Old Aug 28, 2004 | 01:34 PM
devon's Avatar
Thank you for your response.
We have checked the fuses and everything fine. The bulbs are brand new.
Old Aug 28, 2004 | 08:04 PM
keyfoo's Avatar
You didnt say if car is auto or manu, but usally there is a switch located in shift linkage. try jiggling shifter in reverse area with someone watching lights, may be bad switch or needs adj of linkage.
ikes4ever
Mar 2, 2018 06:55 AM
kc2mrg
May 21, 2011 07:32 PM
Red XC
Sep 10, 2006 01:59 AM
vwkid3
Feb 26, 2006 11:11 PM
Red XC
Jan 20, 2006 08:34 PM
