reverse lights
Old Jan 11, 2008 | 04:54 PM
ikes4ever's Avatar
Default reverse lights
my reverse lights turn on and off when i am in reverse. any ideas?
Old Jan 11, 2008 | 07:19 PM
Default RE: reverse lights
Sounds like a bad connection in the PNP switch.
Old Jan 12, 2008 | 09:25 AM
ikes4ever's Avatar
i guess this is under the transmisssion selector?
Old Jan 12, 2008 | 09:35 AM
It is mounted to the top of the transmission where the shifter cable attaches.
Old Jan 12, 2008 | 10:57 AM
Psaboic's Avatar
Is it both bulbs at the same time, or just one? You might want to check the bulbs for tightness in their sockets, and also check the fuse for the reverse lightsjust to eliminate the easy things first
Old Jan 12, 2008 | 08:33 PM
ikes4ever's Avatar
its both of the bulbs. i notice if i put slight pressure on the gear selector towards the front of the car they work fine
Old Jan 12, 2008 | 08:45 PM
Then that would be your PNP switch going bad. It would have nothing to do with the bulbs.
Old Mar 2, 2018 | 06:55 AM
860ARE's Avatar
I dont have any reverse lights either. Car drives fine. The lights do flash when i set alarm though. I replaced PNP with one from fcp and it was faulty part and stuck in limp mode.. I put old one back on. No lights again but at least no limp mode.
Lszul
Feb 11, 2008 07:50 PM
Red XC
Sep 10, 2006 01:59 AM
vwkid3
Feb 26, 2006 11:11 PM
Red XC
Jan 20, 2006 08:34 PM
devon
Aug 28, 2004 08:04 PM
