reverse lights on/off *neutral safety switch
Old Jan 18, 2006 | 02:26 AM
Red XC's Avatar
Default reverse lights on/off *neutral safety switch
I got a question:
I replace my neutral safety switch awhile back, which made a loud sound at the starter. and smoke starting to come out of the gear selector which a old wire grounded itself. SO i replaced it, but i notice my reverse lights sometimes doesnt come on.. So i was look at my rear side mirror.. and notice if i pull the gear selector a little back while at reverse the light goes on, and push it forward lights is off.. so i guess is some loose connections somewhere. maybe on the groove to the selector. any ideas?
Old Jan 18, 2006 | 08:46 PM
Default RE: reverse lights on/off *neutral safety switch
You might also have to adjust the shifter rod under the car. If the bushings are worn or new ones installed then you might need to adjust the rod slightly.
Old Jan 19, 2006 | 01:31 AM
Red XC's Avatar
Thanks for the reply tech!
Which bushings were you talking about? And how do I adjust the rod slightly. Sorry I dont really know how to repair my 240.
Old Jan 20, 2006 | 08:34 PM
There is some bushings where the Rod goes from the body of the car. The shift bucket under the car to the transmisson. Some cars have 2 bushings some have 3 and some have 4.
You will have to look and see if your Rod is adjustable. If it is then you will see a nut and threads.
jonqu
Aug 26, 2013 08:31 PM
AnEskimo
Jun 11, 2013 08:15 AM
troutfanatic
Jul 14, 2012 08:21 AM
nuthinbutmacs
Oct 8, 2011 04:20 PM
petes99xc
Feb 10, 2007 10:24 AM
