wiring an amp in the 850
Old Mar 4, 2006 | 01:55 PM
cool_kyle_3000's Avatar
Default wiring an amp in the 850
i have the cd/tape deck in my car and i was wondering how to wire in the amp because it dosent have 2 rca jacks in the back. there was a thing u could buy that had the 2 rca jacks that i needed but i had to hook it up to the 4 speaker wires but there are more that 4 wires going into the back of the deck. anyone kno what to do?
Old Mar 4, 2006 | 04:55 PM
Default RE: wiring an amp in the 850
Buy 2 of them or buy one and Use the Y Adaptor for the RCA's and use a 4 channel Amp.
It is kind of hard to find the matching DIN jacks for the Amps.
Old Apr 16, 2006 | 08:25 PM
rp850's Avatar
Not sure if this is what you're looking for but this cable will allow you to connect an aftermarket head unit to the factory amp:
http://www.quickbrickmotorsports.com/prod_dincable.html
Old Aug 21, 2006 | 06:29 AM
gullyg's Avatar
Sorry to bump this but,
Does this mean that the amp is separate to the head unit in the 850? I want to put a standard phono output through the built in speakers, hopefully keeping the car as standard as possible to reduce cost and allow me to remove the system and put the 801+Changer system back in when I got to sell the car.
Basically I'm thinking of removing the SC801 in my 850 T5 and replacing it with a 7" LCD touchscreen hooked up to a mini-itx or Mac Mini based system in the boot (trunk in the US?). I'm hoping to setup an mp3 system with gps and bluetooth phone connection with the help from a Electrical engineer friend.
(I'm a computer scientist)
Old Aug 24, 2006 | 09:35 PM
ko_kidd's Avatar
I've got a 740 and I tried doing the DIN but I came to find out the DIN doesn't carry the sound, unless I'm mistaken somehow.
(I had the speaker wires hooked up based on this:
http://www.volvospeed.com/obd2/RCA-preouts2.htm
and I only got audio from the front speakers I hadn't attached to a new amp)
Old Aug 25, 2006 | 12:19 PM
cbevis's Avatar
I'm not 100% sure on this but i'm pretty sure factory amps don't push the speakers, they push the head unit....sort of like a pre-amp. if you have an aftermarket deck in your car you don't really need the factory amp.
aben132
Nov 12, 2014 10:03 AM
sdl92
Jun 22, 2013 07:19 PM
Echoe
Aug 26, 2009 12:08 PM
Echoe
Engine & Internal
Aug 20, 2009 12:07 AM
huzzsaba
Apr 2, 2009 05:35 PM
