How do you delete a text message?
Old Oct 3, 2004 | 03:53 PM
tfolkner's Avatar
Default How do you delete a text message?
I have a 2003 S80T6. It is over a year old. I want to delete a text message and cannot see in the manual how to delete the message. The message is
"On Call Plus Deactivated". This also causes the warning light /!\ to come on.
Is there any way of deleting the annoying message?
Also there is a leak of power steering fluid. I can't find it, but the reservoir needs refilling once every month. Has anyone had a similar problem?
Thanks for your help,
Troy Folkner
Old Oct 3, 2004 | 07:08 PM
Default RE: How do you delete a text message?
I will check on the message for you.As far as the leak check the hoses at the reservoir they are prone to leak there also check at the pump.If not there also check the metal lines at the steering rack the bolts on some of them weren't torqued properly causing them to leak.check those places and let me know.
Old Jun 18, 2005 | 08:19 PM
jlw253@yahoo.com's Avatar
Did anyone ever answer this one (re: how to turn off the on-call message.) I just purchased a 2004 T6 and am having the same problem. It's really annoying.
Old Jun 18, 2005 | 11:10 PM
reg's Avatar
reg
I had a power steering leak also. I and the dealer could not find the leak....................the dealer changed every hose and etc. Finally the pump was changed and voila..............no more leak!! So...............ask the dealer to change the pump and perhaps your problem will be solved.
Old Mar 6, 2008 | 03:40 PM
TitaniumGreyS60's Avatar
Wow no answers in years Holy crap.
I have the same problem....
Looks like I have to go elsewhere!
Old Mar 6, 2008 | 11:29 PM
JPN's Avatar
JPN
Moved from New Members Area. Due to its age I did not notify the original poster.
This post has been dug up after years, but the forum has changed with great members and I believe someone would be able to answer this question. I moved this to General Volvo Chat rather than the S80 forum, as moremembers can take a look at it.
JPN
Old Mar 7, 2008 | 12:12 AM
1999S80T6's Avatar
ORIGINAL: TitaniumGreyS60
Look no further buddy... you are at the right forum. I will bet you can find solution for your problem in this forum.
Good luck.
rspi
Dec 5, 2012 12:44 PM
theflemingcrew
Jan 2, 2011 01:44 PM
doublegranch
Jan 30, 2010 08:22 PM
chakrv1
Mar 27, 2009 05:37 PM
GeoffC
May 10, 2006 08:33 PM
