Factory PSI
Old Oct 31, 2004 | 03:43 PM
riaf28's Avatar
Default Factory PSI
I need to know what the factory wastegate is set at on a TD05-12B, thanks in advance
Old Nov 1, 2004 | 04:52 AM
Vender's Avatar
Default RE: Factory PSI
I believe it's around 7 PSI
Excuse me if im wrong its 3AM
Old Nov 1, 2004 | 01:55 PM
riaf28's Avatar
can I just replace the spring in the wastegate with an HKS spring at my desired PSI?
Old Nov 2, 2004 | 01:00 AM
I've seen people T the vaccum line at the wastegate and install a regulator to adjust boost after adjusting wastegate rod almost all the way.They use the regulator to adjust the boost.
Old Nov 5, 2004 | 11:45 PM
Vender's Avatar
As Tech has said you can just do a basic Boost Controller Install. You can either go for the mechanical kind, which is installed right into the vacuum line (sp? lol), which is a very simple install or you can go for an electronic kit which requires a little bit more work.
What PSI are you aiming for? Cause you can't just install the controller and crank out 15psi without doing other work on it first. This ain't no Fast and Furious![:'(]
Old Nov 8, 2004 | 08:49 PM
riaf28's Avatar
I got the turbo for a low psi kit for my car. I was looking for about 5 or 6 psi, I'm no fast and the Furious wannabe. I really wanted to keep it simple, so do you think the HKS spring will work in the wastegate.
Old Nov 10, 2004 | 06:23 PM
You might be at that psi already.
Old Nov 11, 2004 | 06:32 PM
Vender's Avatar
5-6PSI? If you're running a stock TD05-18B from factory, you're running at ~7 psi...
What exactly is your set up? and what exactly are you trying to run for your kit?
Old Nov 12, 2004 | 04:17 PM
riaf28's Avatar
I'm using a TD05-12B on my 2.4L Cavalier. The kit will be intercooled but since I'm not looking for mind blowing horsepower I want it set at about 5 or 6psi. I'm looking for about 200whp that doesn't require too much boost on my engine.
Old Nov 16, 2004 | 03:49 PM
riaf28's Avatar
Do you know if the Volvo TD05 uses a standard TD05 exhaust flange, I about to order a mani but the guy who makes the turbo manifolds is in Michigan. Any info will be great.
Old Dec 21, 2005 | 10:43 AM
At 7 PSI you will be fine. That is good for 200 Hp. Since I am running a 13g and stock the PSI is 5-7 PSI. and my Hp rating was 193 and torque was 210.
Old Jan 14, 2006 | 10:26 PM
jturkey69's Avatar
you will actually be over that.... what year cavi? did you swap out the stock intake mani for a H.O. unit?, with 7 psi you should be around 220 whp...check out grandamgt.com....there are a couple of guys running the 2.4 and runnin low 13's and high 12's in a grand am
boostnm3
Jan 1, 2011 05:29 PM
TURBOSNAIL
21
Jan 16, 2008 11:43 PM
ENDEE666
Jan 13, 2008 03:48 PM
S70R
May 12, 2006 09:16 PM
code33
Mar 8, 2006 08:20 PM
