More PSI From The 2.5L Turbo
Old May 12, 2006 | 04:01 AM
S70R's Avatar
Default More PSI From The 2.5L Turbo
I was reading a thread on adjusting the PSI in the turbo, and the 2.5L Turbo S70 wasn't mentined at the bottom where it said "This information does not apply to..." and was wondering if it was just a misprint, or if there is something funky with it.
I know it is a simple yes and no answer, but I just dosn't want to send the engine through the hood if the motor can't take the adjustment.
Thanks
Old May 12, 2006 | 12:25 PM
S70driver's Avatar
Default RE: More PSI From The 2.5L Turbo
Where is this other thread? I would like to read it as well.
Old May 12, 2006 | 08:57 PM
S70R's Avatar
http://www.ipdusa.com/pdf/wastegate_...4_02_turbo.pdf
Old May 12, 2006 | 09:16 PM
Yes it can be done. Not all cars like it though.
These cars have a Boost control Valve. Some cars the Valve will stop the boost.
But most cars it will work on. You will have to try it and see.
It won't Blow the engine. If it goes into over Boost it will fall flat on its face. Just like going full boost then shutting the car off.
boostnm3
Jan 1, 2011 05:29 PM
Saleen9090
Feb 16, 2009 05:48 PM
MC92
Jan 28, 2009 12:55 AM
miller guy
Apr 23, 2008 11:29 AM
