92 960 sagging bad
Old Nov 1, 2006 | 11:12 PM
92volvo960's Avatar
Default 92 960 sagging bad
I searched to see if this was a problem thats been adressed already but didnt see anything. Anyways my 92 960 sags in the back pretty bad. If i have any one sitting in the back im dragging the exhaust every wheres. Just wondering what i can do to correct this. Should i get new spring/struts? Any info is really appreciated. Thanks in advance!
Old Nov 3, 2006 | 12:02 AM
Default RE: 92 960 sagging bad
What type of suspension do you have?
The shocks are most likely bad. You most likely have Nivomats and they are REALLY expensive.
Old Nov 3, 2006 | 09:34 AM
92volvo960's Avatar
Hmmm not sure what they are. If they are really expensive I guess Ill just have to learn to like the sound of my muffler hitting the payment haha. Ill do a little more research and see what i can do.
Old Nov 3, 2006 | 10:00 PM
Look under the car and see if you have a Solid Axle or Indipendant rear suspension.
If you have Axles in the rear that look like front wheel drive Axles it is not a Solid Axle.
They have a single Fiberglass rear spring so those shocks are needed.
If it is a solid Axle and you have the nivomats you can put in heavier springs and Gas shocks.
leamangriffin
Suspension
Sep 28, 2018 03:35 PM
trooperone
Sep 1, 2011 10:02 PM
plumonium
Apr 7, 2011 12:03 PM
buddyglassjr
May 4, 2009 11:54 AM
emf
Suspension
Jun 29, 2008 12:03 PM
