Penta Discuss Volvo Penta Marine Machines Within.
Possessed Starter AQ225D
Old Nov 13, 2006 | 08:30 PM
btuck's Avatar
Default Possessed Starter AQ225D
Boat's been laid up two years.
Clean engine compartment, check connections. Follow Volvo "Launch" procedure from operator’s manual, yada, yada.
Put in new battery, move battery switch selector to "Battery 1" and shazaam, starter engages.
A most startling experience I assure you.
No key in ignition. Checked connections at solenoid (all tight no inadvertent contact between posts.)
Tried disconnecting ignition wires at both ignition switches, same result.
Spooky.
Any ideas greatly appreciated.
Old Dec 5, 2006 | 08:08 PM
btuck's Avatar
Default RE: Possessed Starter AQ225D
Guess I stumped the state.
Turn on bilge pump, starter whirls.
Turn on nav lights, starter whirls.
Found problem.
Rats nest.
Sucker chewed insulation off several hot wires.
gjoe
Jun 29, 2009 09:42 AM
notny41
Nov 7, 2007 10:38 PM
transypat
Sep 4, 2007 04:22 PM
jerryman
May 9, 2006 09:06 PM
850GLT
Sep 8, 2005 01:07 PM
