Spare Tire Mounting
Old Jan 31, 2005 | 09:36 PM
krujo's Avatar
Default Spare Tire Mounting
This may sound like a "petty" gripe, but recently purchased an S60T and was getting ready to go on an extended trip. When I started to check the spare tire, I find that the valve stem is not available when in the mounting position. Had to remove the hold-down, then pull the tire partially out to check the tire pressure. In all my years of driving, I have never seen such poor human engineering. Talked to the Dealer and his answer was, "Duh, most people don't check their spares anyhow". It seems to me that an angled extention on the valve stem could fix this problem.
Old Jan 31, 2005 | 09:38 PM
Default RE: Spare Tire Mounting
I agree I have complained about that for years.It makes it worse when you have to empty an entire turnk just to check the spare tire.
Old Feb 11, 2005 | 01:19 PM
krujo's Avatar
Hi: Found a solution to the problems, although not perfect, it does save unloading a full trunk just to check a spare tire pressure. The solution I purchased is from www.campingworld.com and they are 135 degree valve extenders. The part no. is 18398 and they run $12.99 for a set of two. I admit they are "pricey", but they do the job and you can at least check the air in the tire if you install one of the extenders. Hope this helps someone.
Old Feb 11, 2005 | 01:36 PM
Thank you for posting a soultion that will help someone else on the forum as well.
olegb
Feb 18, 2013 01:04 PM
HummerGuy
Oct 10, 2008 08:02 AM
Pretorien
May 3, 2006 09:07 PM
muzkman
Apr 3, 2006 02:06 PM
hanknum
Dec 14, 2005 08:07 PM
