740 Timing belt and valves
Old 09-28-2010, 12:21 PM
zozz111's Avatar
Default 740 Timing belt and valves
My 1990 740 blew a timimg belt right thru it's plastic casing. I was told that this probably bent the valves and I will most likly need a new head.
Thoughts?
Old 09-28-2010, 01:46 PM
ed7's Avatar
ed7
ed7 is offline
Not likely, but could happen if the valve stuck in the guide. Another head is not always the answer either. Valves are cheap.
ED7
Old 09-28-2010, 08:24 PM
swiftjustice44's Avatar
Assuming you have the B230F, it is a non-interference engine. If you have a GLE with the dual cam B234 then you may be hurt. The real issue when cam belts break is whether it was the cause of the issue or the result of an issue. I've seen a few seized cams from poor oiling that froze and broke the belt. If that's the case then a new head may very well be in your future. When the cam seizes, it pretty much ruins the cam journals.
Old 09-29-2010, 06:34 PM
zozz111's Avatar
Thanks. How do I know if I have a B230F?
Old 09-29-2010, 07:02 PM
TURBO 245's Avatar
1st pic is a B234,second pic is a B230f.
Dan
Attached Thumbnails 740 Timing belt and valves-16v.jpg   740 Timing belt and valves-b230f.jpg
Old 10-01-2010, 12:09 PM
bigdaddyrdpjr's Avatar
My timing cover states the motor size also look on the id plate
johnhon
01-11-2021 09:13 AM
rbroy
03-24-2008 09:51 PM
girlie
12-26-2007 09:52 PM
itsagirl
01-29-2006 06:36 PM
Quick Reply: 740 Timing belt and valves
