88 240 misfire/hesitation under acceleration
Old 10-19-2017, 09:48 AM
Roger M's Avatar
Default 88 240 misfire/hesitation under acceleration
Question for the troubleshooting experts:
My 1988 wagon(5 speed manual) has developed a miss/hesitation when I'm accelerating, particularly in first and second gear. It seems to be getting worse as time goes by(it started about two weeks ago).
I did clean the throttle body about a month ago, as well as a tune up(plugs,cap, rotor). I did replace both fuel pumps a couple years ago, along with the strainer/filter. i'm hoping the pre-pump hasn't failed already.
Any help is appreciated.
Old 10-20-2017, 10:40 PM
missing/hesitation can be an ignition system problem, or a fuel delivery problem.
Old 10-20-2017, 11:45 PM
lev's Avatar
lev
lev is offline
Really? I guess that's how you get 8,700+ comments...
Old 10-20-2017, 11:49 PM
lev's Avatar
lev
lev is offline
Roger M. Start with a tune up, the basics, plugs, wires, rotor, cap... When is the last time you tuned it? Check for vacuum leaks, too. Go from there.
Old 10-20-2017, 11:51 PM
well, its not like he gave us much to go on.
hmm, 88 240, thats got the chrysler ignition system on the right fender behind the headlight... if the vacuum line to the ignition control unit is leaky or loose, that can mess with the spark timing, which could cause power loss as you apply throttle.
is the problem worse when the gas tank is closer to empty, and less to none when the tank is full? that points to the in-tank pump.
jcjcrespo
11-11-2014 10:02 AM
Will1147
07-28-2013 02:21 PM
court.smith0817
11-12-2011 10:19 AM
nola740T
10-06-2010 11:43 PM
audiobiz
03-08-2008 05:06 PM
Quick Reply: 88 240 misfire/hesitation under acceleration
