Charging Prob
Old 07-23-2015, 01:11 PM
yeah, local auto parts store, heh, sorry.
  #22
Old 07-23-2015, 01:54 PM
Surefiregs's Avatar
They did not have them so in going to just change the connector. Is there a reason it would not self excite at 2,500 tho?
  #23
Old 07-23-2015, 02:02 PM
sometimes they do, sometimes they don't. you could try starting it, and bridging B+ to D+ with a cliplead or whatever, that should kick the alternator on.
  #24
Old 07-23-2015, 02:07 PM
Surefiregs's Avatar
If I do it with a multimeter will that work? From the b+ to d+?
  #25
Old 07-23-2015, 02:09 PM
Surefiregs's Avatar
And if I can do it with the multi do I have to hold it there or can I let go and test the battery after a certain time?
  #26
Old 07-23-2015, 03:19 PM
i'd use a cliplead, I dunno.
or just go ahead and fix the D+ wire so its done right. as i said, a .75" long piece of 3/8" wide brass strip the same thickness as a spade lug, drill a hole in one end for the D+ stud on the alternator, bend it at 45 degrees and use tin-snips or whatever to trim the other end down to like .25" wide so the D+ wire's spade will fit over it. done.
  #27
Old 07-23-2015, 08:00 PM
Surefiregs's Avatar
I did that and worked. Thank you so much I fixed it. I had no idea that the person before me put it on wrong and just followed what they did I am so sorry about that.
supaman658
01-15-2007 09:31 PM
c70turbogt
11-16-2006 08:42 PM
CincyStateFreeze
09-10-2006 01:32 AM
MrD
01-01-2006 05:16 PM
moonraker
01-02-2005 11:23 PM
Quick Reply: Charging Prob
